Problems with Codes
Problems with Codes
Ok gotta long story so i'll try and keep it short. I fried my ECM with a predator that was not set back to stock and ever since then its been throwing a P0602 code and recently it threw a P2509 code. However i had a new lift pump installed and the truck was flashed back to stock and the codes went away. My question is that I would like to see if i can send this predator back and have it checked out. I bought it used and the guy before me bought it used and its had multiple problems. I'd really like to use it but am afraid to now thanks.
03 cummins with pred off, straight pipe, afe, filters, Fass lift pump, and adjustable boost elbow.
Re: Problems with Codes
Yeah I they charge $100 or so to look at it....call themdbbori837 wrote:Ok gotta long story so i'll try and keep it short. I fried my ECM with a predator that was not set back to stock and ever since then its been throwing a P0602 code and recently it threw a P2509 code. However i had a new lift pump installed and the truck was flashed back to stock and the codes went away. My question is that I would like to see if i can send this predator back and have it checked out. I bought it used and the guy before me bought it used and its had multiple problems. I'd really like to use it but am afraid to now thanks.
03'/305 Dually 4 x 4
Smarty SSR,62/65/13ss, CFM+
RE: Re: Problems with Codes
Maybe someone can just tell me without sending it in. Every time i put it on my truck it throws a P0602 code which is an ecm programming error and the truck runs badly. It seems like i have a fuel rattle somewhere even though i just put a new fass pump on last week.
