Throttle Boost Request
jferraino
Post by jferraino »
Hello,
can you please provide me with the throttle boost for my current tune:
93CAI
Dodge Charger RT 2007
Thanks.
05094804AJ_custom.drg
(4.25 KiB) Downloaded 106 times
RE: Throttle Boost Request
can you not update your tool to the latest revision?
jferraino
Post by jferraino »
Hi Mike,
thanks for the fast response. Unfortunatley I tried that route and received an error. I searched the forum and as I understand its because I have an older version of the predator. Thanks for your help.
Re: RE: Throttle Boost Request
jferraino wrote:Hi Mike,
Here you go.
05094804aj_mds_smooth.drg
(59.62 KiB) Downloaded 100 times
jferraino
RE: Re: RE: Throttle Boost Request
Post by jferraino »
Hi Mike,
WOW...thanks for the fast reply. I noticed the file name mds_smooth..does this mean I also have a tweak for MDS surging as well and throttle boost?? thanks
jferraino
Post by jferraino »
Hi Mike,
Loaded the tune...big improvement over the previous tune. How much of an increase was adjusted for the throttle boost? Is there any more wiggle room to increase it further ? Didn't see any setting in the modify tune section so I'm assuming its because this is a one off you provided. thanks
If you want more, post last tune written for me again ;)
jferraino
last tune written
Post by jferraino »
Hi Mike,
Here is the last tune written. thanks
05094804AJ_custom_682011.drg
last tune written
(4.25 KiB) Downloaded 99 times
here you go
05094804aj_custom_more_TB.drg
(59.63 KiB) Downloaded 96 times
jferraino
Post by jferraino »
Hi Mike,
As always thanks for the fast reply and the tune. I will load it up when I get home from work today and provide feedback.
jferraino
Post by jferraino »
Hi Mike,
Got the tune loaded and it works perfectly. The lag is definatley gone with the throttle response tweaks and I'm happy with the results. All the best pal. thx
good deal, enjoy!
