Can I view the parameters my Diablo tune is now set at?
hinge
Post by hinge »
Predator 7146 came with the used car I purchased. There is Diablo tune as last tune written. Can I view what the previous owner programmed in this tune without making any changes?
Dubie
RE: Can I view the parameters my Diablo tune is now set at?
Post by Dubie »
You should be able to goto the tune and hit modify and it should have a * by each setting that has had changes made.
If I remember right.
*FYI
That would be the changes marked that you made, not what was changed from the Diablo Tune you installed.
hinge
Post by hinge »
Ok , you were right , I did that procedure and found the previous owner made changes to the Diablo tune. Can I default back to the original Diablo tune, and how do I do that?
yep...
select the diablo tune you want to install... then select Modify Tune... then select Reset All Parameters... select ok/continue, etc to do that..
then press ESC and it should ask you "Install Tune Now?" - answer/select YES, and it will reinstall the diablo tune with the standard settings...
Return to “Predator Ford Gas”
