2008 Ford Mustang GT Differential Gearing
jasonxace
Post by jasonxace »
2008 Ford Mustang GT with 4.6 3-valve modular engine, Spectre cold air intake system , BBK Shorty headers , 3.55 Differential gears, 5-speed manual trans(TR-3650)
I have just recently bought the Trinity T-1000 and was looking at the different options for the diff setup. My mustang came with the 3.55 gearing instead of the 3.31, and the manual trans, but I can't select that gear ratio as close as I can get it is 3.50 or 3.60. Also I wanted to know it there is an available tune for Spectre Performance Cold Air Intake with the stock Maf sensor, perferably using 89 octane fuel? Please let me know.
Thanks Jason
julan
RE: 2008 Ford Mustang GT Differential Gearing
Post by julan »
post ur stock and modified file, I can set them for you through CMR
what is the revision on the Trinity?
jasonxace
Post by jasonxace »
It has the most recent update
No offense, but can you be more specific?
When you fo to options/show information, what is the version listed there?
jasonxace
Post by jasonxace »
To mikel,
Sorry its been a while since I have been able to get online had pc problems. The version is 1r08a.
I also had another problem. I programmed my 08 GT with the 85mm ford raceing CAI tune and it seems to be adding a little to much fuel. Its running about 7% rich after it warms up, there isn't any check engine light on or anything. So if you have a CAI program made just for the Spectre Performance brand could you let me know. Thanks jason
Pull 5% from the global MAF curve to dial it in.
Return to “Trinity Ford Gas”
