2005 F-350 6.0 No increase in performance
Davefromrp
Post by Davefromrp »
Installed the extreme power puck yesterday and there is no noticable performance increase on any setting.....My truck is stock wih exception os a BANKS air intake and exhaust and has only 42000 miles....Im confused as I have read posting stating their amazement at the power increase??
frankl
RE: 2005 F-350 6.0 No increase in performance
Post by frankl »
Dave, Just make sure you have installed the EP correctly, You should be seeing a deference.
Re: 2005 F-350 6.0 No increase in performance
Davefromrp wrote:Installed the extreme power puck yesterday and there is no noticable performance increase on any setting.....My truck is stock wih exception os a BANKS air intake and exhaust and has only 42000 miles....Im confused as I have read posting stating their amazement at the power increase??
Dave, when we first released this part number a couple years ago, there were a few units that had the wrong program on them, that when tested on the dyno did not add much power. We fixed it right away and reflashed all of our inventory, but there may be a few still out there.
I will assure you that you SHOULD feel a difference, and a noticable one at that, so if there is no Check engine light, and the install is correct (its pretty simple, as Im sure you would agree) then please fill out the rma request form on our website, so we can get the Puck back here and update it and get it back to you.
Davefromrp
RE: Re: 2005 F-350 6.0 No increase in performance
Thank you for your responce...Yes the install was very straight forward and there is no check engine light I will send in the punk...thanks for a time responce.
