New Jeep features, new Ram HEMI tunes!
njrobsram
Post by njrobsram »
Hey mike can you add my new calid (68043445ah) or do I have to downgrade?
If the latest crom is asking you to downgrade, it will be necessary for the meantime.
airportdave
Post by airportdave »
Hey Mike- any idea what's up with the shifting in the tune I posted above? Thanks!
2010 Jeep Grand Cherokee Limited 5.7L, QDII
InTune 91 Octane Tune
(Previous Predator User)
TunerTools
Post by TunerTools »
Which of the listed features are Rubicon only? have a customer with a 2007 Unlimited and I don't want to lie to him about the features that work on his JK
Cheers,
Lloyd
www.TunerTools.com
The axle locking and sway bar disconnect stuff is rubicon only.
billcampbell
Post by billcampbell »
Good Morning . I have a PREDATOR #U7137w/9r12 can not ajust tire size. whatother items can perform(gear change/trans firmness) [email protected]
airportdave
airportdave wrote:Here's mine Mike- as noted, big hesitation/pause between the 1-2 and 2-3 shifts. Only parameter mods are throttle boost to 5% and altered speed limiter.
Bump for Mikel. Any luck with this issue? Tune attached above.
give this a shot
pcm_68060516ac_perf_91oct_modified_mod.drg
(73.27 KiB) Downloaded 286 times
airportdave
Will do tonight- thanks!
airportdave
give this a shot
Mike- this one is a little better, but there is still a noticeable hesitation/pause between the 1-2 and 2-3 upshifts, especially at part throttle acceleration. This hesitation is not present in the 9R10 tunes I had been running. The rest of the tune and shifting is the best yet though!
Can you look at these shift points again? Thanks!
can you get a log of it happening with this tune?
give this a shot please.
pcm_68060516ac_perf_91oct_modified_mod_001.drg
(73.3 KiB) Downloaded 255 times
airportdave
mikel wrote:can you get a log of it happening with this tune?
I will Mike, thanks. What PIDS would be helpful for you?
Johans regular list would be fine.
Chinpokumon
Post by Chinpokumon »
Is the: u7137-9t12c.crom - still the latest and most up-to-date tune out there for the Jeep Wranglers 3.8?
Thanks!
2010 Jeep JK Unlimited 4dr, Sliver; 6spd; 3.73; AFE Intake; Viper TB; Thrush Exh; Predator Tuner; 4.5" Lift; 35's on 16x10's.
