2004 gto help with predator
i have a 2004 gto i have a k and n intake jba catless mids and slp loudmouth exhaust nothing major can i use the 93 octane predator tune on this setup? will it work just fine with the catless mids im hoping it does lol help please
RE: 2004 gto help with predator
also if the tune is installed if you unhook the battery will the tune go away?
yes it will work for you.. but you will need to get a custom tune done in order to disable the rear O2's and cat. converter trouble codes...
no... the tune will not get erased/cleared off the pcm...
thank you so much
and sorry 1 more question i have no cats and it smells a little rich is tht just bcuz i dont have cats?
you need to get your fueling adjusted... your mods will have it outta whack, so you need to do some data logging and get things adjusted and dialed in...
what should i do for that i was guna install the performance 93 octane tune what can i do or should i do for the fuel sorry im new at this
also if it is outta whack a little bit can it hurt the engine or juss bad gas mileage
or can the 93 octane tune help with the fuel or help at all with the car and will it perform better or more horsepower?
