So, what is it, fuel flow rate sensor, what is on a 2008 silverado LT 5.3L non flex fuel? I really need help on this one. The normal injectors are cut off (signal interrupted) and the CNG injectors take over when you switch to CNG, the CNG injectors follow the pulse width from the petrol injectors with a correction factor applied.
I just redid the whole system, pulled the head off again and re-did the whole top of the engine for nothing
