OK, I'm new here.
I just received the U7778 PC interface kit from DS - and I'm more than a little aggravated - here's why....
I cannot get this cable to be identified by my Windows 7 OS.
I've followed all directions to the "T" several (more than 10) times now. Used the supplied driver disc,
AND even went directly to Prolific and got their d/l for the file.
Tried again - NADA
I have 6 USB 2.0 ports on my PC - tried them all.
What I DID get from Prolific is this message ...
Q Why do I get an Error Code 10 (Yellow Exclamation Mark) after I installed the latest driver?
A If you are getting an Error Code 10 with a yellow exclamation mark in Device Manager after installing the latest Prolific PL-2303 driver, please contact the cable maker of your product for Prolific chip validity and support.
Prolific strongly recommend to only purchase USB-to-Serial cables from company-branded products providing technical support. It is not advisable to buy from unknown cable makers (no-brand cables) made in China. Prolific does not manufacturer any end-product cables and will not provide direct support to end-users.
any ideas?
U7137 driver issues - cable related? *RESOLVED
RE: U7137 driver issues /USB cable dead
Go into Device Manager and remove the Prolific driver.
Restart the computer.
Then install this driver. http://www.cooldrives.com/lib/cooldrive ... apters.zip
Restart again, then plug in the cable.
It should find it. Open DS Downloader in XP Compatibility Mode. It will not find the Predator in Win7 Mode.
If that driver doesn't work, try this one: http://www.usglobalsat.com/download/546/win_drivers.zip
Thank you
Thank you
Thank you Mike!
Your 1st zip worked for me.
I'm connected now and ready for my update.
Thank you
Thank you Mike!
No problem.
