Trinity - Synthesized Boost not working
I have a 2006 Charger SRT8 with a Magnacharger installed. Trinity has the most current update. It does monitor Baro and MAP PIDs, but the Synthesized Boost PID always reads zero (In monitor mode). The MAP PID does show increasing boost with increasing RPM and Baro minus MAP gives around the expected boost value. I currently have the following gauges configured on the dashboard: Intake Charge Temp, Baro, MAP, and Synthesized Boost.
What do I need to do to get it working?
RE: Trinity - Synthesized Boost not working
Can you post a log?
Re: RE: Trinity - Synthesized Boost not working
Sure, what PIDs do I need to log?mikel wrote:Can you post a log?
RE: Re: RE: Trinity - Synthesized Boost not working
Log MAP, BARO and RPM. Also, Make sure you have 1r08a of dcx_gas.
Are you on the latest 1r08b?
awesome.
I'm on 1r08c and the boost pid maxes out at 2.90. I set the range at 0-20. Any thoughts?
However when I go back and review the log in DataViewer I see Map and Baro are correct and doing the math the PSI is right. It's just like the display isn't showing it properly.
Also, any reason we can't have a "boost" pid on Data Viewer? Seems it'd be easy for that program to do the maths for us.
hmmm...question...what if you use a different type of gauge for the boost pid?
