Just wondering if you can use DSlogredux WOT function and conversion with the U7198? Most recent editions etc. Did a log of my cruise and LTFT and checked with Ds and it wants -1% on the injector slope. But when I go to check the WOT burst section it says nothing? Or no WOT datareduction U7198/79/92 etc. Any help??
Im guessing it wont do the WOT log analyze with the 7198? Thanks again guys. If this is the case what is the best way to adjust the PE settings?
U7198 Dslogredeux WOT?
RE: U7198 Dslogredeux WOT?
no....
7198's do not have the AFR parameter available to data log, so no WOT suggestions for you...
generally, you can go half the amount of your injector slope setting... so, if you went -2% on the slope setting, you can go -1% on the WOT/PE settings....
