9r29 crom: Why Raise Shift Points?
rham48
Post by rham48 »
I have searched thoroughly, couldn't find the answer. I thought those of us with RTs shouldn't monkey around with the shift points, only SRTs. Can someone explain the benefit of doing this and how far you can safely raise the shift points? Thanks much.
AZ MSCL: Inferno Red 09 Challenger RT, Aria CAI, Moroso Catch Can. 2010 Silver Mustang GT Premium.
RE: 9r29 crom: Why Raise Shift Points?
safely is up to you, alot of people like the 6000 rpm shift points on the 5.7s
neonsox
Post by neonsox »
I've been doing a lot of reading, and most people seem to think the factory did a good job of hitting the shift points. I guess the 5.7 doesn't benefit from revving to 6k as the power band cuts out in the high 5k area. I didn't do it because the redline is something around 5700 for a reason.
2008 Dodge Charger R/T - 5.7 Liter V8 HEMI
K&N Drop-In, Stock Otherwise
rham48
Re: RE: 9r29 crom: Why Raise Shift Points?
Post by rham48 »
neonsox wrote:I've been doing a lot of reading, and most people seem to think the factory did a good job of hitting the shift points. I guess the 5.7 doesn't benefit from revving to 6k as the power band cuts out in the high 5k area. I didn't do it because the redline is something around 5700 for a reason.
Exactly. While I'm not knocking the feature (love my Predator) I questioned the purpose of raising the shift points. More is not always better but to each his own.
RE: Re: RE: 9r29 crom: Why Raise Shift Points?
you guys should also consider that all the 5.7s out there are not stock.
Anyone with heads/cam swaps and especially a centrifugal blower, will instantly see a 20-40 rwhp gain by being able to rev it out a bit.
Id also wager that the 6000 rpm shift points would perform a bit better at the dragstrip than the stock points, but I'm sure someone will test it.
rham48
Re: RE: Re: RE: 9r29 crom: Why Raise Shift Points?
Post by rham48 »
mikel wrote:you guys should also consider that all the 5.7s out there are not stock.
Didn't think of that. I'm up for giving it a shot at the dragstrip. Only have CAI, catbacks and 91 CAI tune.
HEMI08
RE: Re: RE: Re: RE: 9r29 crom: Why Raise Shift Points?
Post by HEMI08 »
IM all about it, Im going to the track and tear it up. I have ben waiting for the ability to raise the shift points for two years. I have built My engine to make power out past 6400. I immeadiatly set the shift points to 6400 as soon as I updated to CR29. I'll have solid #s this weekend. I expect to have a lower E T and more top end MPH. If not Ill try seting the shift points at 6k. If not Ill set them at 6400 and buya tranZformer and set them at 6200 ..etc... I hope I blow up my rear end so I have to upgrade to an LSD. So meanwhile anyone not wanting to rev past 5800 can leave it alone. Im glad diablo figures out how to add this CHOICE.
abuelo
Post by abuelo »
9r29 hast only 3 shift point options; stock 6200 & 6400-----doesn't it?
HEMI08
shift points
Post by HEMI08 »
I belive that the shift points are stock ( menu probably says no cange) , 6k and 6400. I posted 6200 with the Tranzformer. I would set the shift points @ 6400 with the diablo and then 6200 with the tranzformer. Trazformer can set shift points at any point bepow the diablo threshold. I was just making the point that the new feature gives us many more possibilities...if we want them.
rham48
RE: shift points
Post by rham48 »
Is 6000 the magic number for an 09 RT with CAI, Corsa catbacks and 91 CAI tune? I have not installed 9r29 yet. Further recommendations are appreciated. What's a Tranzformer?
jmgak47
RE: shift points
Post by jmgak47 »
With your mods I would say between 6k - 6.2k just tweak it till you find a sweet spot. Generally you want to shift 1-2 sooner then 2-3. Your motor is done making power at 5.8k ish then is slopes off. The only reason to shift higher then your peak HP is to get a higher shift recovery. You want to come in right around your peak TQ if possible.
Build a hemi right and it will love to rev!
rham48
Re: RE: shift points
Post by rham48 »
jmgak47 wrote:With your mods I would say between 6k - 6.2k just tweak it till you find a sweet spot. Generally you want to shift 1-2 sooner then 2-3. Your motor is done making power at 5.8k ish then is slopes off. The only reason to shift higher then your peak HP is to get a higher shift recovery. You want to come in right around your peak TQ if possible.
I loaded the new crom 9r29, but only found an option for cancel, stock, 6200 or 6400. Is there somewhere else to adjust it to 6000?
Sscarpaci
RE: Re: RE: shift points
Post by Sscarpaci »
Ram, I have a 2010 R/T 5.7 and installed the 93 CIA tune today at the 9r28 Crom. Can you or anyone tell me what difference I will see with th 9r29 update?
Also I found that the 93 CIa tune give me great mid range and off line line not so much... I am running 94 Oct Sunoco gas (always have) with a OCtane Booster... HAve you tried the 91CIA v 93 CIA?
Pinky
2010 Dodge Challenger R/T 5.7
K&N CIA
Magnaflow Catback
Diablo 93CIA Modified Tune
Which booster are you running? Unless its the NOS Race Booster, its doing you no good and will end up fouling your plugs. And you need to get a catch can on there ASAP if you don't have one.
jmgak47
Post by jmgak47 »
I would stick with the 6.2k then. I have a Ram so my options are different.
