emissions urgent
Thomaswhitt
emissions urgent
Post by Thomaswhitt »
I need to get my tags on a new vehicle i purchased with a tune in it. My jeep will not run on factory defaults so I need the CMR tune modified to pass emissions. I have been told the o2's and monitors are turned within the tune.
I will pay whatever it takes as I need my car. I will try to attach the tune to this message. If someone could please reply that would be great. My email is [email protected]. Phone# 423-313-1531
68041665AB_Mark Hudzik_custom_henson.drg
(60.56 KiB) Downloaded 518 times
(60.56 KiB) Downloaded 480 times
The rear o2s are turned back on here, but if you dont have stock or really good aftermarket cats its likely going to throw P0420/P0430 codes.
68041665ab_mark_hudzik_custom_henson_O2.drg
(60.56 KiB) Downloaded 492 times
Thomaswhitt
My vehicle will not idle correctly with the modified tune in it. If you try to put it in drive it idles down too low and tries to die. Im going to put the old tune in it until i hear back from you guys.
can you load the tune I made then export last tune written and post it here?
Thomaswhitt
both tunes are at the top of this page. Iam running the one i sent you now. When i load the o2 tune into the jeep it doesnt like it.
too late... gone til Tuesday...
Thomaswhitt
I attempted to attach the two tunes. Thanks if you can help. If you have any other questions you can call me.
68041665AB_custom.drg
this is the one the jeep runs on now
(6.25 KiB) Downloaded 471 times
68041665ab_o2modify.drg
this is the one you sent me with the o2's turned on.
(60.56 KiB) Downloaded 477 times
johan
Post by johan »
I just checked the files, and what Mike sent you should not affect the operation of the vehicle one bit, might have something else going there, all he did was enable the rear 02's.
Johan< @ >DiabloSport.com
Diablosport INC
Research & Development
