Error Message Pls assist
RE: Error Message Pls assist
exactly the same message..., where r u living?
Re: RE: Error Message Pls assist
In Bahrain brocoliseum wrote:exactly the same message..., where r u living?
RE: Re: RE: Error Message Pls assist
i have an 06 RT Road and track... With the traffic here in Dubai, dunno where to test all this added power i am getting!!
^ yeah was in Dubai back in June,, couldnt beleive the amount of traffic.. maybe you can drop by in Bahrain, we got a few empty roads to test on
:p
Hi Mikel... This is to recap my issue... hope you guys get to sort it out today...
I see that some of my Aussie friends got their to work... I am still getting the same error... its very frustrating... When I press on the Calibration Updater, I still get:
"The server reported an error, please contact diablosport or try again later, the error reported was CAL 05187100AB is not handled"
To add to this, when i got the predator out of the box, the first thing i did was plug it in the car. I did not upload a CROM file into the predator. Also, it did not even backup the Original program of the car like I read is happening with some of the other guys... in my case, it tells me within 1 second that i need to update by visiting diablosport.com/dcx which is giving me the above error.
Can you please ensure that the CAL I gave you will be supported... please I need this to work as I think I cannot return the device anymore, it has been with me for almost a month. Not to mention I really want it to work!
Is there a way I can wipe out whatever original file the predator is refering to and reset it to factory default so i can try again?
G'day guys.
Please follow these instructions as they may be of assistance.
This will only be applicable to those who have received the update file from Diablo. Anything else please PM me.
Step by Step instructions.
Please uninstall and delete all existing Diablo programs and files.
Please reinstall the most current DS Downloader http://www.diablosport.com/downloads/pr ... .9.6.2.exe
Please copy this file to an easy to locate area on your computer (Your desktop or C:\temp would be best) http://www.diablosport.com/downloads/pr ... 8t16a.crom
1. Please copy and save the updated file from Diablo to an easy to locate area on your computer (Your desktop or C:\temp would be best).
2. Start up DS Downloader
3.Connect Predator to your computer/downloader
4. Under Express Tune Mode click Send CROM file to Predator. Here it will ask you to locate the file you saved prior (8t16a.crom) and update to predator. Ensure that when it is done that this version is shown at the top of the Predator. It will look like this – Predator v.8t16a.
5. Run the Calibration update. This should allow you to do so. This will take around 2-5 minutes (maybe longer depending on connection speed)
6. Take Predator out to your car. Before plugging it in ENSURE EVERYTHING IS TURNED OFF. Radio, interior lights, aircon, anything plugged into cigarette lighters unplugged etc. Ensure wipers are off also.
7. Plug Predator into your car and follow instructions on the screen.
8. Allow Predator to save stock backup tune from your car. Start to finish here may take around 10 minutes. It is normal for headlights to stay on during this process as well as to turn on and off a few times.
9. Once completed it will now ask you to update you Predator from Diablo's website. This is also normal even though you have downloaded 8t16a.crom.
10. Going back to your computer, re connect Predator to your PC & DS Downloader. You now need to update/load the attached file received from Diablo into your Predator. This is file 8t16x.crom. Load this the same way you did step 4. Once download is complete it should now work on your car. (DO NOT USE CALIBRATION UPDATER AGAIN).
11. Connect Predator back into your car and away you go.
Any questions please feel free to contact me.
