can't log KNK?
can't log KNK?
I can't log KNK ST,LT It shows up wen i select it in the PIPS. Then i select record and it shows run time but it does not record? WHY? I've up dated data viewer plus wen i try to data log with my Predator and select KNK ST,LT it shows up and it wont record? So i believe that the KNK might be turned off in my tune. Is that possible? Please Help.
RE: can
The values will be zero unless your PCM is actually pulling timing because of knock. Sounds like everything is working fine.
