u7137 modified tune
Lanz_17
u7137 modified tune
Post by Lanz_17 »
i have a 2007 dodge ram 1500 5.7l with twin air intake and magnaflow dual exhaust
i am looking to modifie my settings sush as throttle responce and shift points
i do a lot of off roading aswell as speed
is there a program i can upload (e-mail) to my diablo chip unit
or can sumone help me with settings so i can manualy modifie my settings for something better for what i do
thank you
frankl
RE: u7137 modified tune
Post by frankl »
with your mods listed you can use anyone of the canned tunes in the tool. if you are on 9r12 you have the throttle booster, which well help add a bit more "pep" the the truck.
Lanz_17
Post by Lanz_17 »
alright i have tempted to update my predator tuner with the 9r12 and it had failed when i power it up it says the application is missing or corrupt, please help!
Lanz_17
Post by Lanz_17 »
now i have red off the diablosport downloader that i should connect the predator to the pc but dont power it up then click the auto connect off and then power up the unit to download the 9r12...once i am ready to dowload the file the window freezes and does not want to download...am i able to get back my original program that i had before i tried the update?
backroads
Post by backroads »
I am having the same problem!! I have followed every step to fix the corrupt or missing data. it downloads step 1 of the file and when it graduates to step 2 to reboot the "the application is missing or corrupt" returns to the screen and freezes the process. please help this Thread!!!
Lanz_17
Post by Lanz_17 »
maybe the 9r12 is a currupt file?! or mayne we have the wrong braud band and the drive wont support the file to the programmer...
Lanz_17
Post by Lanz_17 »
can anyone help ive tried everything, maybe diablo sport needs to re program my programer.
give us a call with the tool at the PC, we'll walk you through it.
wheeliesteve
Re: RE: u7137 modified tune
Post by wheeliesteve »
frankl wrote:with your mods listed you can use anyone of the canned tunes in the tool. if you are on 9r12 you have the throttle booster, which well help add a bit more "pep" the the truck.
My 7137 came with 9r12 loaded from the factory. It doesn't seem to have a "throttle booster". where would I find this?
Steve
RE: Re: RE: u7137 modified tune
thats in the adjustable parameter menu...
wheeliesteve
Re: RE: Re: RE: u7137 modified tune
mikel wrote:thats in the adjustable parameter menu...
Okay, I found it, thanks! How much should I increase it to see a noticible difference on the 93 perf tune?
Steve
RE: Re: RE: Re: RE: u7137 modified tune
try 10% to start...
wheeliesteve
Re: RE: Re: RE: Re: RE: u7137 modified tune
mikel wrote:try 10% to start...
Thanks Mike, that seemed to give it a little more pep! Would it hurt it to bump it on up to 20%? or does that just make it use more gas?
Steve
