91 Tune on 93 oct
prohunter
91 Tune on 93 oct
Post by prohunter »
Is it safe to run 93oct on a 91 tune for a V6 charger
bighemitex
RE: 91 Tune on 93 oct
Post by bighemitex »
that's fine, just as long as you don't run lower octane than the tune is rated at. if anything using slightly higher octane will help prevent knock. I use 93 with the 91 tune all the time and it gets better results than the 93 tune and 93 octane
2003 RCSB Hemi Ram - Stock 20s, U7137, AIRAID CAI, 180* Jet T-Stat, Black Magic E-Fan, 3 Inch Cutout, Hooker Aero Chamber Muffler, TMR Mod, NGK 5306 plugs, Taylor 8.2 thundervolt wires, Pacesetter Longtube Headers, Pacesetter ORY, magnaflow cat, Innovate LC-1,
prohunter
Post by prohunter »
Ok I tried the 91 tune on 93oct and it seems to be better on the 93 tune and 93oct. Now my question to u is should I play with the timing?
Don't mess with the timing. If its better on the 91 tune its because it likes less timing. The only difference between the 91 and 93 tunes is 2° of timing.
prohunter
Post by prohunter »
It seems better on the 93 tune with 93 oct and 15% thorttle boost and tire size set
