2001 DT 466 with an M1000 Powerpuck | no difference at all
TunerTools
Post by TunerTools »
Hi guys,
I have a customer with a 2001 DT 466 International. With an M1000 connected, there is no measurable difference at all in the HP or the way it runs and this has been checked on a local dyno there. It's not throwing any MIL light, not running any worse, but it's not running any better either, in fact it's like nothing was even plugged in.
Have you ever seen this before? I have not. I have seen a couple where the connections were wrong or the Powerpuck defective, but those all threw a MIL light and went into limp mode. In this case, it's like nothing was even plugged in.
Please advise
Cheers,
Lloyd
www.TunerTools.com
RE: 2001 DT 466 with an M1000 Powerpuck | no difference at a
Lloyd, in this case it sounds like the diablo dial may be the culprit.
When the dial is unplugged (or not working) the puck is simply a pass through device, which is what sounds like is happening here.
If you have anopther puck, please try swapping out the dial (simple plug in), and if that works, we'll simply get another dial out to you asap.
Let me know.
TunerTools
Hey Mike, there was some additional information he told me today that I didn't have before. It's definitely bad.
I'll email an RMA request in.
Cheers,
Lloyd
www.TunerTools.com
Got it, thanks.
meetpeter
Post by meetpeter »
hey guys,
i am new in this forum and i like the concept.
i want "2001 DT 466 with an M1000 Powerpuck"
can you tell me how can i get it??????
thanks in advance!!!!!
Contact Lloyd at TunerTools
www.TunerTools.com
misterfruehling
Post by misterfruehling »
ive got two 2005 international 4300 .. dt466 ... i got two pucks , same trouble as first post, they have no efect on power what so ever on eather truck, tryed enterchanging the parts but no sucsess.
i ordered them on fri and got them today and they don't seem to work
my trucks are idetical shop trucks they wiegh 24000lbs right now they go up the steeper grades at 40mph with the pucks atached it does not change
No codes or issues, as if nothing happened?
misterfruehling
yeah no codes , they just act like nothing has happened
Are you sure the MAP is connected at the middle and the Fuel at the end?
