Predator Tune - 2004 Corvette
yes...
BUT, what was your intake air temp when you did the log?
if the intake air temp was only in the 70's or low 80's, then I would leave it set at the -4 and not make the change... because once the normal warm/hot summer weather hits, then your fuel trims will drop more... so if they're at 1.xxx now, then when they drop you'd be right in the range that you want to be at...
during the normal warm/hot summer weather for your area, is when you want the average ltft's to be around -2...
Scorpion
Post by Scorpion »
Lew,
Thanks!
The Intake Air Temp was exactly as you stated. I'll reset my LTFTs back to -4% and wait for the hot temps to come in (someday).
You're my Predator God! :mrgreen:
2004 Corvette
A4 Transmission
Blackwing Intake
Magnaflow Exhaust w/X-Pipe
U7193 Release 9r11
:lol:
Scorpion
Post by Scorpion »
06MonteSS wrote:yes...
Lew,
When I run my latest Log on DSLogRedux, I get this error message when I click on the "Verify Log Parameters": "The maximum number of parameters handled by this application is 40. Please trim your csv file, or log fewer parameters"
What is your recommendation? How do I trim my csv file?
2004 Corvette
A4 Transmission
Blackwing Intake
U7193 Release 9r11
Rally2SS
Post by Rally2SS »
scorpion wrote:
Lew,
I know, I'm not Lew, but...
I trimmed some of the unnecessary stuff out of the file, and ran it through redux and it came up with -2 slope adjustment
...BUT...The data looks weird!
e.g. log shows 138.6MPH @ 5% throttle/800RPM (time 00:34:xx) then DECREASES to 134.8MPH @ 9% throttle/989.8RPM (time 00:56:xx) then starts to look normal around time 1:28:xx
Also, the time seems to be skipping hundredths of seconds
I think you should log with fewer parameters..looks like you're sending too much data for the recorder to keep up with.
If you want to trim yourself, just open the .csv in excel and delete the extra columns (right click on column letter and choose delete) then save as .csv (ignore any warnings about 'lost functionality')
Hope this helps!
Lew,
it means you logged too many parameters man... you have to delete some from the log file...
the less parameters you log, the better the log will be, because it will be able to sample/read the data quicker...
for your 04 vette, the only parameters you need to select to log are these:
Long Term fuel trim bank 1
Long Term Fuel Trim Bank 2
Spark Advance
Intake air Temp
MAF Sensor Mass Air Flow
MAF Sensor Frequency (you may not have this one)
Knock Retard
Engine Speed (RPM)
Absolute Throttle Position
Rally2SS wrote:
scorpion wrote:
Lew,
Hope this helps!
I agree ^ ^ ^ ^
Scorpion
Post by Scorpion »
Rally2SS wrote:
scorpion wrote:
Lew,
Hope this helps!
Rally2SS,
This is more information than I have. Thanks for your input.
2004 Corvette
A4 Transmission
Blackwing Intake
U7193 Release 9r11
Scorpion
Post by Scorpion »
Lew,
Thanks[/quote]
Spark Advance
Intake air Temp
Knock Retard
Engine Speed (RPM)
Absolute Throttle Position[/quote]
Lew,
Thanks! Looks like I'll be doing some more logging this weekend.
Summers finally here in the Northwest and traffic's getting heavier. I'm trying to carefully log some WOT but it's becoming challenging.
How important is it to log some WOT?
I'll have to find a huge parking lot or try to find a small runway to use!
2004 Corvette
A4 Transmission
Blackwing Intake
U7193 Release 9r11
Scorpion
Post by Scorpion »
OK... Now that I adjusted my LTFTs to -6%
Should I adjust my PE -3% in all three RPM ranges?
2004 Corvette
A4 Transmission
Blackwing Intake
U7193 Release 9r11
yes, you can...
Rlyoun
Post by Rlyoun »
Oh yeah... THANKS FOR HIJACKING MY THREAD!!! NOW I GOT TO SCROLL THROUGH ALL YOUR B.S. JUST TO GET TO MY STUFF :punisher:[/quote]
OH...If WE Have a question we have to START a New Thread...Instead on Replying to a Thread That seems appropriate???
Then there would BE MILLIONS of threads...Instead of reading PAGES of related Items in question...We would Have to Go To a Million Different Threads???
I am New to this web searching bit and OLD School...Also I am Just Trying to Find Out as Much Info as I can on these Diablo Tuners...So That I can Just Purchase ONE THAT I Can Use With-Out having to send it in for New Programming???
