U7194 Pinging in 87 Tune
toydriver00
Post by toydriver00 »
First, let me start this off with, I had a pinging issue in my Avalanche with the Edge Evolution using 87 octane.
Now, I am using a Predator on my Silverado and I have a similar issue. The predator tune is not as bad as the Edge tune. In WOT, I don't have pinging (at least that I can hear), but as the truck drops into 4cyl mode and I lightly touch the gas it pings. Also, when the truck is in 8cyl mode and slowly raising speed it pings. I put the truck back to the factory tune, and after a few miles the pinging stops. Should I be concerned?? I have not received my USB/Serial cable from Newegg yet, so, I can not log any information....
jimmybuckets
RE: U7194 Pinging in 87 Tune
Post by jimmybuckets »
Sometimes it takes a while for the new tune to settle in...I don't get any ping...but i'm using 93 on a custom tune. Try pulling some timing out and see if that helps or see if it goes away running 91.
toydriver00
I have it back on factory right now so that I can take the truck into the dealer in the morning. I should have my USB cable tomorrow. I will load the 87 tune back up after the visit at the dealer and drive it for 20-30 miles. I drove 40 miles this weekend with the tune in and I had no problems. I am thinking that I may have gotten some bad gas this morning. I will find out when I drive it home from work tonight. If it is still pinging then I know it is the gas.
BTW-Yes I am the same guy in the GM site--Just a different name
Yeah, my money is on the bad gas.
Let us know.
toydriver00
Mike-
What is the process to get a custom tune from you?
Sean
If it is something we decide we could/would/should do then you email us a copy of the backup file from the Predator and we send back a new tune.
Like I said though, there would not be much we could do for you in a tune given your mods.
You can always contact any of our CMR dealers who will be happy to make you a custom tune.
toydriver00
The only CMR dealer here closed down. The next closest is 250-300 miles away. I do only have a K&N intake. I took it out this morning as well as the tune trying to find the source of a whistle under my hood. (it is the PS pump). I will post up tonight about pinging with the factory tune. Then, tomorrow, after the dealer is done, I will put the 87 octane tune back in without the K&N intake and see what happens.
Thanks for your help,
Sean
toydriver00
It is the gas. The truck pinged, but not as bad when it was on the factory tune.
Return to “Predator GM Gas”
