WOT spark calibration?
I have the u7194 and I logged my truck and got the WOT power enrichment adjustments set but are you supposed to use the same adjustments for the WOT spark calibration or what?
RE: WOT spark calibration?
uhhh, no....
I wouldn't change the timing/spark adjustments.. the timing is already advanced pretty good compared to stock...
what tune are you using? what's the truck?? what octane gas??
Im using the 87 octane tune with 87 gas in a 08 silverado with 5.3
definitely don't increase the timing/spark advance... leave it as is...
I have a question about power enrichment. I understand the concept of the three WOT rpm ranges under power enrichment but when changing them do you always change all three ranges the same? What am I missing?
Mike R.
Mike R.
Firerader
Re: WOT spark calibration?
I also have a question you say not to adjust spark but I did a wot run at the track and only had 23* timing with 3* knock that its giving me 20* that seems low to me even when I get the knockout can I adjust wot spark without messing with anything else
