I have two questions:
1. If I do the quick adjust to turn off the ESP/ABS, I loose the cruise control.. I push the on button and no cruise.
2. also I noticed that if I push the ESP button, then turn the car off and back on, the ESP/ABS is now active again which leads me to believe this turns the system back on and overrides the quick adjust..is this the case? I now have to do the quick adjust again using the predator to turn it all back off again?
thanks for the help.
2010 Charger SXT
Predator model U7136
ESP off using quick adjust and I loose cruise control??
RE: ESP off using quick adjust and I loose cruise control??
Whenever you disable the ESP you lose the cruise control. It also disables the brake assist and ABS. Its not meant to be turned off, thats why it resets after you turn the car off. Its a safety feature, and disabling it is meant for the dyno only.
got it. thanks!!
