Is this advisable or waste of money?
Any suggestions for this?
I have my LTFTs dialed in but I want to adjust other parameters.
Logging & Modifying Performance Tune on the Dyno
2004 Corvette
A4 Transmission
Blackwing Intake
Magnaflow Exhaust w/X-Pipe
U7193 Release 9r11
A4 Transmission
Blackwing Intake
U7193 Release 9r11
RE: Logging & Modifying Performance Tune on the Dyno
no harm in dialing it in in a controlled environment to ensure all is well
Thanks Mike!
So I would do the same logging as I have done before but now I can get a good WOT run in without heading off to jail
and getting my Corvette impounded.
I suppose that after my logging and uploading to my PC, DSLogRedux will analyze my readings and suggest lots of changes
2004 Corvette
A4 Transmission
Blackwing Intake
U7193 Release 9r11
A4 Transmission
Blackwing Intake
U7193 Release 9r11
not for your 04 it won't... you can't log the AFR parameter on your car with that predator...
see what it's running for an AFR while using a wideband o2 sensor on the dyno...
