u7137 modified tune
u7137 modified tune
i have a 2007 dodge ram 1500 5.7l with twin air intake and magnaflow dual exhaust
i am looking to modifie my settings sush as throttle responce and shift points
i do a lot of off roading aswell as speed
is there a program i can upload (e-mail) to my diablo chip unit
or can sumone help me with settings so i can manualy modifie my settings for something better for what i do
thank you
thank you
frankl
RE: u7137 modified tune
with your mods listed you can use anyone of the canned tunes in the tool. if you are on 9r12 you have the throttle booster, which well help add a bit more "pep" the the truck.
alright i have tempted to update my predator tuner with the 9r12 and it had failed when i power it up it says the application is missing or corrupt, please help!
now i have red off the diablosport downloader that i should connect the predator to the pc but dont power it up then click the auto connect off and then power up the unit to download the 9r12...once i am ready to dowload the file the window freezes and does not want to download...am i able to get back my original program that i had before i tried the update?
give us a call with the tool at the PC, we'll walk you through it.
- wheeliesteve
Re: RE: u7137 modified tune
My 7137 came with 9r12 loaded from the factory. It doesn't seem to have a "throttle booster". where would I find this?frankl wrote:with your mods listed you can use anyone of the canned tunes in the tool. if you are on 9r12 you have the throttle booster, which well help add a bit more "pep" the the truck.
Steve
RE: Re: RE: u7137 modified tune
thats in the adjustable parameter menu...
- wheeliesteve
Re: RE: Re: RE: u7137 modified tune
Okay, I found it, thanks! How much should I increase it to see a noticible difference on the 93 perf tune?mikel wrote:thats in the adjustable parameter menu...
Steve
RE: Re: RE: Re: RE: u7137 modified tune
try 10% to start...
- wheeliesteve
Re: RE: Re: RE: Re: RE: u7137 modified tune
Thanks Mike, that seemed to give it a little more pep! Would it hurt it to bump it on up to 20%? or does that just make it use more gas?mikel wrote:try 10% to start...
Steve
