Calibration update failure
I just received a predator for use with my '05 300c 5.7. I am getting a calibration update failed message when I attempt to use predator. This attempt also results in trouble code "u1113 unknown". Cal Id is 04896405AJ. Any help?
RE: Calibration update failure
Have you done the DCX Calibration Update? Did this error occur when trying to install a tune?
Christy High
lurker.
lurker.
I downloaded a calibration update, but it will not successfully install on vehicle. I can't attempt to install a tune because I cannot get beyond the calibration update stage. When I use predator I get the calibration updating progress bar, a calibration update failed message, and I also get a trouble code out of the deal.
Revision 17 solved this issue. Thanks.
