U7158/03 lightning.Is there any benefits in adding a MAFia?
ivanivan242
Post by ivanivan242 »
I have a 03 Lightning and a u7158 Diablosport Predator w/ a custom tune from Steeda to run a 4lbs crank pulley over stock boost.. Other mods are: BBK twin 65 mm throttle body, Bassani X-pipe catback exhaust and K&N air filter.
Would there be any HP benefit from adding a MAFia mass airflow tuner device to the stock ford 90mm MAF?
Ivan
ChrisDiabloSport
RE: U7158/03 lightning.Is there any benefits in adding a MAF
Post by ChrisDiabloSport »
The MAF.ia. will not add any HP. The only reason you would need to install a MAF.ia. is if you are getting close to pegging your MAF. Normally with a 4# pulley you are pretty safe from pegging the MAF. I recommend adding a MAF.ia. if your MAF_V is getting close to 4.8 Volts or 980 counts.
Thank You
Chris Johnson
1865 S.W. 4th Ave. Suite D2
Delray Beach Florida 33444
Phone: 561-908-0040
Fax: 561-908-0048
www.diablosport.com
ivanivan242
Thanks...
Return to “Predator Ford Gas”
