Been running the 87 Octane Tune in my '09 Z71 with fuel levels dialed in (+2 on spark advancement) for a couple months now. Just for kicks today, I ran a log running at 75MPH on smooth interstate to get my RPMS in the 1800-2000 range in the dry, 103 degree TX heat to confirm that everything was dialed in where it should be...
Ran the log and it says I need to go to +3 on the spark...is this minor adjustment recommendation really necessary? Truck seems to be running like a champ as it sits now...thank you for any advice!
I have attached the data log file for anyone to examine
Further Adjust or Just Leave It Alone???
fightinfarmer2010
fightinfarmer2010
RE: Further Adjust or Just Leave It Alone???
Also, just as a side-note, the previous log was ran under similar conditions (dry, +100 degrees, smooth interstate)
+3 on spark advance/timing??? no....
you need to adjust the injector slope, not the timing/spark advance...
fightinfarmer2010
I meant injector slope, sorry
Haven't touched the spark adj
fightinfarmer2010
Recommendations anyone?
- smokestack
Re: RE: Further Adjust or Just Leave It Alone???
Do as lew stated. Adjust the injector slope. Do a nice long log and see what the values are. Then adjust as stated in the logs...fightinfarmer2010 wrote:Recommendations anyone?
Not much you can do from there. Other than send lew your logs and get a good tune done.
Read this http://diablosport.com/index.php?name=P ... opic&t=917
And this http://diablosport.com/index.php?name=P ... ic&t=21643
