U7135 v9r29
Dodge 2010
Charger R/T
Went to the performance tunes and adjust tune, but didnt find the MDS listed.
Did the Canned Tune 91 CAI Perf tune I installed, automatically turn off the MDS?
Or is there some other way to do this?
Please Help!
How to turn off the MDS?
PhilBrentjr
RE: How to turn off the MDS?
Ok went for a drive, the MDS is still on. Is it able to be turned off? or do I have to re-install the Stock OEM tune and then mod the MDS? and if so.. if I re-tune it for the 91 Oct CAI canned tune, will that over write the MDS being turned off and turn it back on? Please help.
its int he modify tune menu after you select the tune you wish to modify.
Re: RE: How to turn off the MDS?
Go back to the 91CAI tune and select it. Then you will see install tune and below that you will see modify tune. page down to modify tune and select it. you can now go through and find MDS and turn it off. When your done hit the ESC button until it ask you if you wan't to install the tune. hit yes and it will load the 91CAI with the MDS off. You do not need to return the car to stock to do this. Print these instructions so you will have them in the car with you. These are not the same as the ones that came with the predator. They go into much more detail. Hope this helps.http://www.case-enterprises.com/xeryder ... edator.htmPhilBrentjr wrote:Ok went for a drive, the MDS is still on. Is it able to be turned off? or do I have to re-install the Stock OEM tune and then mod the MDS? and if so.. if I re-tune it for the 91 Oct CAI canned tune, will that over write the MDS being turned off and turn it back on? Please help.
Sorry could not get the link to copy and paste. Try this http://www.case-enterprises.com/xeryder ... edator.htmbrandy16 wrote:Go back to the 91CAI tune and select it. Then you will see install tune and below that you will see modify tune. page down to modify tune and select it. you can now go through and find MDS and turn it off. When your done hit the ESC button until it ask you if you wan't to install the tune. hit yes and it will load the 91CAI with the MDS off. You do not need to return the car to stock to do this. Print these instructions so you will have them in the car with you. These are not the same as the ones that came with the predator. They go into much more detail. Hope this helps.http://www.case-enterprises.com/xeryder ... edator.htmPhilBrentjr wrote:Ok went for a drive, the MDS is still on. Is it able to be turned off? or do I have to re-install the Stock OEM tune and then mod the MDS? and if so.. if I re-tune it for the 91 Oct CAI canned tune, will that over write the MDS being turned off and turn it back on? Please help.
singerofchrist
Re: How to turn off the MDS?
I have a I3 tuner wanting to turn off the MDS on Ram 2013. I go to modify parameters and the MDS option is not there. Is not available to do or where or what do I need to do?
hmm, what do you see in that menu?singerofchrist wrote: Tue Jul 25, 2023 1:29 am I have a I3 tuner wanting to turn off the MDS on Ram 2013. I go to modify parameters and the MDS option is not there. Is not available to do or where or what do I need to do?
is there a 'switches' group?
Same here with my 2011 Durango.singerofchrist wrote: Tue Jul 25, 2023 1:29 am I have a I3 tuner wanting to turn off the MDS on Ram 2013. I go to modify parameters and the MDS option is not there. Is not available to do or where or what do I need to do?
In the modify parameters all that's there is tire size and traction control.mikel wrote: Thu Jul 27, 2023 4:12 pmhmm, what do you see in that menu?singerofchrist wrote: Tue Jul 25, 2023 1:29 am I have a I3 tuner wanting to turn off the MDS on Ram 2013. I go to modify parameters and the MDS option is not there. Is not available to do or where or what do I need to do?
Josh
that sounds like the quick adjust menu, if you are sure you are selecting the modify parameter option, give us a call, 561-908-0040
Ok, say you already installed your tune rather it be 87 octane, 91 CAI, or 93 Octane, you have to install a tune of your choice first. Then if you want to turn MDS off, you choose the tune, the go to modify parameters, then you will see MDS on / off. Select off. the download tune. You don't have to go back to stock tune to do these steps. have a great day.
