2011 Mustang GT A/F
2011 Mustang GT A/F
Just wondering when the wideband reading for a/f will be available through the trinity?
RE: 2011 Mustang GT A/F
our guys are working on that as I type this
I see Revan Racing is currently using this feature, what are we looking at for an update release?
email sent
Re: RE: 2011 Mustang GT A/F
Is that good news? [email protected]mikel wrote:email sent
RE: Re: RE: 2011 Mustang GT A/F
Test crom is coming your way Bud!
It has the WB PIDs, but they are not added to the existing layouts yet, go in and add them to the layouts and you'll be good to go
Success, Thanks again Mike,
works great!
What about this for the Shelby GT500?
2011 Ford Mustang Shelby GT500
RE: 2011 V6?
should have a release version up today
Darkside323
RE: 2011 V6?
Hello just wonder if the A/F gauges will work on an 07 GT500
RE: 2011 V6?
2011+ Mustangs and 2009+ F150's only. The earlier mustangs do not have wideband oxygen sensors
- Scuba-Matt
RE: 2011 V6?
2012 Mustang GT
Got the update with the wide band, When I go to customize my own gauge layout I can only get one lambda gauge and one A/F . No previsions to change both to A/F or both to lambda. Are these reading off both O2 sensors or only one? Thanks, Matt
RE: 2011 V6?
Lambda and A/F are measurements of the same thing using both sensors so if you set both gauges to one or the other it would be like have two identical gauges at all times which is not useful in my opinion. Lambda is totally not useful because it based on the assumption that a lambda value of 1 = an A/F of 14.7. A/F ratio = lambda x 14.7
Usually the lambda shown with the predator or the trinity is the commanded (intended) value that the PCM wanted. If that is the gauge you have pulled up along side the new a/f ratio gauge then it may be useful to see if the lambda (commanded value) matches the actual a/f ratio picked up by the sensors.
