I install the new revision 8t16a.crom, to my diablosport, and still the fan turn on always, I got a Charger R/T, I would like to know the fan setting:
L =
M=
H=
Fan always on U7135
RE Fans on all the time
The Predator tune is designed with a 180 degree thermostat in mind. If you replace the stock thermostat with a NAPA THM 165, Motorad 4128, or Jet Performance 10183, the fans will match up perfectly. If you choose to maintain the stock temperature thermostat the fan temp should be modified. There are numerous posts associated with fan temp settings utilizing stock thermostat. I do not know the right settings for best performance with the stock thermostat.
RE: RE Fans on all the time
To get the correct stock settings for your vehicle, you can go into Modify Stock Tune and look at the settings for the fan temps.
Christy High
lurker.
lurker.
Re: RE: RE Fans on all the time
If Diablo set fan for 180 stat at 190 low 199 high I would think you could set fans at 213 low 222 high as stock stat is 203degrees this would give you the same spread that they used. Stock settings are real high 219 low 226 high.christina wrote:To get the correct stock settings for your vehicle, you can go into Modify Stock Tune and look at the settings for the fan temps.
crazylikeacharger
terremoto09
