Can't add fuel with MPG Booster Tune U7135
I just installed my wideband & I've been trying to add fuel but is doesn't seem to work. The tool takes the change and flashes the car, but it doesn't seem to make any difference (my afr before & after is roughly 12.8-13) even adding 20% more fuel all along the range. Am I missing something?
shocknawful
AFR-fuel adjustments
I'm pretty sure the fuel trim adjustments are only for WOT conditions in the "modify tune" section.
Are those AFR reading taken @ WOT?
RE: AFR-fuel adjustments
Yes, everthing is at WOT..
thats kinda lean, sure you are not removing fuel?
add 20% then post up last tune written.
The AFR is basically the same before & after I added the fuel....here is the tune with the added fuel.
- PCM_68052005AD_MPG_Booster_Tune_modified_maxFuel.drg
- (2.25 KiB) Downloaded 185 times
what revision are you running?
Today I tried that tune (with maxed fuel) and loaded it as a custom tune, reseted the parameters and maxed the fuel again. It did seem to have some effect, but not as it does with the 91octane tune.
One additional info is that I live at 8000 ft above sea level, so the max MAP I'll get is 76KPa (even with switch on - engine off) can it be some influence?
this is based on a wideband, correct?
