2010 camaro 2ss o2 rear sensor delete
erikmoore132
Post by erikmoore132 »
Okay, I'm having problems with the longtube heards/ cat delete pipe... it only supports 1 o2 sensor per pipe. I ordered the predator because i heard that they have a program that supports that. Now i wont receive the predator for a couple of days... My question is, will just that predator take care of the problem that i can only use 2 of 4 o2 sensors or am i going to have to get some interface kit and or a custom tune? If so I'd like some help with that if at all possible
erikmoore132
RE: 2010 camaro 2ss o2 rear sensor delete
sorry i've searched everywhere i just couldnt find anything on the camaro
erikmoore132
lol and how do i move this to the predator section SOOOORRRRY
Ill_Born_SS
Post by Ill_Born_SS »
Your rear O2 sensors will have to remain in place (attached to wiring) and tied up securely!
You will need a CMR tuner/dealer to correct the codes related to your mods... a custom tune is way more advisable.
Recommended tuner: http://www.diablewtune.com/ (Lew will walk you through every step required)
Yes you will need the interface kit or a cable and power adapter from a local store like The Source. It is required to be able to update your unit and also for transfering data and tunes to your computer.
" Just Friggin Wicked"
Now with TCM support...
you have to get a custom tune done... the predator nor trinity can disable the necessary trouble codes/items.. that functionality was removed years ago due to EPA regulations...
erikmoore132
ok, pmed lew about a custom tune, how does that work? my car has been disconnected from a battery for a week so i dont even have a baseline on my stock ecu right? or does it just load the stock parameters. Lol I'm use to a dyno tune, the flash thing always seemed too good to be true but i decided to give it a shot this time.
replied to your pm....
Gardner5604
Re: 2010 camaro 2ss o2 rear sensor delete
Post by Gardner5604 »
Is the predator 2 platinum able to remove them? I mean, this tuner is used for race only and my race car doesn't have cats. If not, why would it not be able to and can this be an update to the tuner program.
No device will offer this option out of the box, it must be done through custom tuning.
and you'd want to get the inTune i3 8245 Platinum tool if you want/need to get a custom tune done for your car...
Return to “Trinity GM Gas”
