Trinity tune hard shifts
hamalmarzooqi
Post by hamalmarzooqi »
Hi,
I just tried the trinity performance tune on my denali 2009 however i tried that there is no improvement in the 0 to 60 however the shifting was very hard? Is this normal and safe?
RE: Trinity tune hard shifts
How are you measuring 0-60?
Shifting should be improved, that is normal.
hamalmarzooqi
I am using the drag option in the trinity.
But i fell that its very hard and mifht affect the transmission?
we can soften it up a bit if you post up your backup file and last tune written.
hamalmarzooqi
Hi,
please find attached the original factory tune and the diablo tune.
i would like to reduce the hardness of the shifts and gain more HP if possible.
PCM_630501631174_Diablo_Tune.grg
last tune written
(5.25 KiB) Downloaded 237 times
PCM_original tune.grg
original tune
(66.77 KiB) Downloaded 250 times
here ya go....
hamal_shift_softer.grg
(56.14 KiB) Downloaded 238 times
hamalmarzooqi
thanks, i will try it and update you
hamalmarzooqi
Hi,
i tried the tune, but my gauge became missed up! it reached 200 km lol while i was driving 100 only!
i think this is becouse i played with the tire size before i gave you the file.
i am attached the files again without and changes to tire size. can you please do the change again to soften the shifting.
PCM_630501631174- Original Backup.grg
(66.77 KiB) Downloaded 294 times
(5.25 KiB) Downloaded 239 times
hamalmarzooqi
Hi,
Any update on the above please
hamalmarzooqi
hi,
i tried the new tool file you gave me, however the shifts are still hard and not smooth? can you make it softer even more?
should be able to get to this on Monday, we've been kinda slammed.
hamalmarzooqi
thanks alot and appreciate the efforts.
i will be waiting.
hamalmarzooqi
hi,
i am still waiting for the new file with softer shifts
JohnHarrison1
Post by JohnHarrison1 »
My 2010 Camaro was doing the same thing with the Diablo Tune. Actually scared the living hell out of me when it started doing it. I got a custom tune through DiabloLew and it stopped shifting hard. Diablo needs to check there tune before they cause someone transmission problems. If I were you I would get a custom tune with Diablolew its worth every penny!
hamalmarzooqi
i agree with you custom tune is the best. but my concern is that diablotune should be acceptable. even if it will add more power as promised, it should be still safe and runs smooth. this is the whole idea of getting the device in the first place.
and i am still waiting for the feedback from the guys at diablo sport
Return to “Trinity GM Gas”
