Trinity/Zt-2
General Trinity Support
HalsMag
Trinity/Zt-2
Post by HalsMag »
I haven't found the settings to get this to read with the Zt-2 gauge.
Anyone have the trick?
I've set the purple wire to linear, and both it and the white wire show leaner reads than the LCG display or PC log.
2006 Mag R/T 05/05 build
AFE2, 383 stroker, Inertia ported 6.1 heads, SRT shorties, high flow cats, Solo cat back.
Zeitronics W/B, Builder bill Flex plate, TC and Trans.
gizmodo
RE: Trinity/Zt-2
Post by gizmodo »
What are you entering for the values? What version ZT-2 do you have? You should use 9.6 and 19.6 for the low and high values respectively.
You also need to ground the analog cable to the same place as your ZT-2 is grounded.
HalsMag
RE: Trinity/Zt-2
Post by HalsMag »
Changed to those settings, but it's still about .3 low on that scale at idle.
gizmodo
RE: Trinity/Zt-2
Post by gizmodo »
Your ground might be bad then. Be sure the analog cable gets the same ground as the ZT-2.
HalsMag
RE: Trinity/Zt-2
Post by HalsMag »
Same ground.
gizmodo
RE: Trinity/Zt-2
Post by gizmodo »
Check all your connections then. I have the same setup and the AFR in the Trinity is dead on with that of the ZT-2.
Return to “General Trinity”
