05-2010 4.7 Ram support added!!
If you can post up a copy of the last tune written fromthe Predator I'll gladly provide a custom tune to fix the issue.
tech@diablosport.com
No 2011 support yet...
- UARPerformance
eventually, we will add support for non HEMI SUV applications.UARPerformance wrote:Possibly 2006 4.7 Commanders?
2008 1500 4.7L no throttle response.
Ok, we finally got the truck back so that I can get you what you need to fix the issues.mikel wrote:If you can post up a copy of the last tune written fromthe Predator I'll gladly provide a custom tune to fix the issue.
He is trying to run the standard 87 octane tune.
2008 Dodge Ram 1500 4.7L
9r11
problem is that there is no throttle response and the "check gauges" light comes on constantly (gauges are all correct)
Craig
- PCM_05094374AG_Perf_87oct.drg
- (3.25 KiB) Downloaded 899 times
Give this file a shot please
- pcm_05094374ag_perf_87oct_00a.drg
- (74.39 KiB) Downloaded 853 times
Sorry, but if anything its worse...
Check gauges light is still on and now it idles high (over 1000rpm in neutral) and surges at idle.
On initial startup the truck has moderate throttle response, but after about 15 seconds it starts to surge and throttle response goes to nothing. (if you hit the gas the truck will almost stall)
OK, are you 110% sure you loaded it properly?
If so, please try this one:
- pcm_05094374ag_perf_87oct_00b.drg
- (74.39 KiB) Downloaded 889 times
Good deal, let me know.
so far, no bueno...
I am reloading the tune from scratch to see if there is something going goofy.
Feel free to school me if there is a special something I am supposed to be doing. I never know so much that I cant still learn.
I save the files under the customer name so that I dont mess anything up - original backup goes in its own sub-file and custom tunes go in a sub-folder of their own.
Normally I will just load the new tune over the old tune and let it do its thing. This time, just to be sure, I have restored the original backup and loading the tune from there.
I do appreciate your time... thank you!
load the tune I gave you, then export the last tune written from the tool and post it here please.
newest file didnt seem to matter much.
Idle is still all over the place and it almost acts like its misfiring at lower rpms (it isnt, but the idle has that rhythmic sound like a miss)
At startup the engine goes to 1700rpm for about 30 seconds then drops to 1100, then the surge really kicks in.
Check gauges light is still on within about 15 seconds of starting the truck (I checked, all the gauges are reading well within the "normal" range)
With revision "A", the throttle would work for about 100 feet or so, now the throttle doesnt work at all - if you floor it the truck will stall.
Loaded the factory tune back in and went for a drive just to make sure that it isnt the truck doing something stupid.
Trying to give you as much info as I can think of, hope I am not just muddying the water.
Thanks!
Thanks!
sorry, just saw this... here is the last tune - exported from the toolmikel wrote:load the tune I gave you, then export the last tune written from the tool and post it here please.
- PCM_05094374AG_pcm_05094374ag_perf_87oct_00b_1705094374AG.drg
- (3.25 KiB) Downloaded 834 times
