Revision Update Instructions
(for Trinity, please see Trinity Update Instructions):
PREP:
NOTE: DSDownloader does not work with Belkin brand USB-serial cables
Purchase
http://www.diablosport.com, click Products, then Online Store
-buy part #U7778 for PCs that have USB ports, OR U7777 for PC’s that have a serial port
OR
from Radio Shack, Best Buy etc:
-USB to Serial cable OR a straight 9-pin Serial/Serial cable
and a
-12 v 1 amp power cable, 2.5 x 5.5 mm jack- center pin is positive
Download the Software:
Go to http://www.diablosport.com click Support, then Downloads, enter Vehicle Type or Predator Part number (U71##):
Tip: Make sure to download all files by right-clicking the link and selecting “save asâ€
Revised Instructions: Predator Update
- j.mike@diablosport
- Revision Update Instructions Predator pdf.pdf
- Open with Adobe
- (97.07 KiB) Downloaded 2451 times
mtkaboater
RE: Revised Instructions: Predator Update
I did all of the steps listed above. It all worked quickly until now that I'm on step 11. I'm watching the Preditor tool waiting for the re-boot... it has been 5 minutes and the same message is still on the tool's screen and it says "Installing Boot Loader"..... how long should this take?11. Watch the tool, it will reboot once the file has finished transferring. If it is a Predator, wait to see the new revision displayed at the top line of the main menu before unplugging it. At this point, you may take the tool to the vehicle and install the Performance tune.
Any day out on the lake is better then a day at work!
