Manual transmission installed 2005 ram
dabramwski
i installed t56 viper transmission in my 2005 dodge ram 1500 hemi works with no tune but looking to tune it out so no check engine codes sombody help?
- CUSTOM DODGE RAM TUNE.drg
- (5.25 KiB) Downloaded 303 times
- my05hammer
RE: Manual transmission installed 2005 ram
SWEET!!! LETS SEE SOME PICS!!! details details!!
Sorry, cant I help you with the tune.
You really should tell us what codes you have.....
dabramwski
It is currently throwing a p0700 transmission control sys, p0888 TCM power relay, p0750 Shift Solesrt10noid A code I dont have many pics of install but will take some of finished product will post up soon i used a trans out of srt 10 viper with a quicktime bellhousing had a custom driveshaft made by a local drive shaft company used a mopar performance Mopar P5153592 130 tooth flywheel had a 10.5 clutch made by falcon clutch on long island used the hydraulic cylinder for throwout from a 2005 srt dodge ram and pilot bearing from a 2010 challenger only problem i had was input shaft clearance in the crank shaft luckily i had a good crankshaft from a 2500 5.7 manual which had correct depth for the input other than that had to mod the bell-housing because the lx oil pan and tranny dust shield are all one part and that is what the bell housing i used was designed for but just drilled 4 holes to line up with truck dust shield still looking for a starter that will work have been pop starting it still but is a ton of fun to drive and love the mod just need to work out the engine codes and tune it for best performance .
dabramwski
Heres some pics
- DSCN0062.JPG (100.7 KiB) Viewed 5369 times
- DSCN0063.JPG (96.9 KiB) Viewed 5369 times
- DSCN0064.JPG (89.4 KiB) Viewed 5369 times
- DSCN0065.JPG (96.8 KiB) Viewed 5369 times
- DSCN0066.JPG (82.94 KiB) Viewed 5369 times
- my05hammer
Very nice setup. For the peddels did you just use a set of factory units from a 3500 with a manual? Did they bolt right in or was there any fabrication required? Lastly, the shift lever... is it a custom peice or did you use an off the shelf item?
After looking through this, it is not as simple to disable these codes on a Ram as it would be a LX car...I think you'll need to find someone that can flash the PCM for you to disable the trans params.
dabramwski
Do you recommend anyone to do a flash on the PCM I am on long island NY ? Also will be looking for tuning for a supercharged 392 soon if anyone can point me in the right direction. Pedals were just bolt in i used setup out of a 2005 srt 10 ram all u need is the the clutch pedal a new smaller break pedal a pin some bushings and a c clip and your in business the bracket that under the dash is already setup for a clutch pedal shifter is also out of a 2005 dodge ram srt 10 as well found it on eBay because the dealer wanted an arm and a leg for it If i can find my slip from the dealer i will post part numbers on pedal setup.
dabramwski
ok so the clutch cylinder is bolt right up might and comes with hose and all part # 5037431aa it cost me $240, you will need 4 bushings part # 52010309ab cost me $2.08, 1 shaft pin part # 52010318aa cost me $2.53 a snap ring to hold it in part # 6023879 cost me $2.07, a clutch pin to link cylinder to pedal part # 52010331ac cost me $2.59, clutch and brake pedals dont remember which was which part # 52009944ac $28.00 and 52010221ac $25.07 and also i have part # for pilot i used 53009180ab $21.68 and shift lever 5037436ab 109.94 Tried to take a picture under dash to give you an idea.
- DSCN0069.JPG (53.25 KiB) Viewed 5357 times
Dude, you're on Long Island, why didn't you just go see AJ at Westbury Jeep? He's one of the top Hemi tuners in the world.
dabramwski
how can i contact him right threw Westbury Jeep? i Will try and get in touch with him tm. hopefully he can help
You can try to get him through Westbury. He's not easy to get ahold of. Call the Service Dept and ask for AJ in the Hemi Shop.
http://www.westburyjeep.com/performance-department2.htm
Ahh, good catch Mike, AJ is the perfect guy for this job
- white_lightning
- my05hammer
