predator # u7146
Predator revision v.9r09
98 mustang GT
twin turbo
72# injectors
I have a custom tune on my predator. The guy at the dyno went back through my tune they other day and cant figure out why my car keeps throwing a code for both my rear o2 sensors "p0136 and p0156" . He told me that he had shut them off in the tune as far as he knows but to contact Diablosport and see if there is something he missed. Not sure how to post my tune. If needed could You give me instructions on how to do so.
98 mustang Gt custome tune issues withe rear o2 sensors
ok i think i figured out how to post the tune but wasn't sure if it would be the custom or the extra so i will post both.
- custom tune.frg
- this is the costom
- (224.25 KiB) Downloaded 281 times
- extra tune.frg
- this is the extra tune
- (224.25 KiB) Downloaded 262 times
There is nothing in that tune that would disable the O2 sensors by any means...why is the idle set so high?
The idle was set high because of my cam's I was told; and when I was coming to a stop the RPM's came down to fast and seemed to make the car die out. What can I do to get these O2's shut off the guy that wrote my tune said he had shut them off and couldn't understand why I was still having the issues?
There are very few changes in that tune, I would never have guessed it had cams. Tell him to use the CMR wizard to turn off the rear o2s.
Tune
u7146.
v.9409
98 mustang
twin 57 mm turbo's
72 lb injectors
t-56 magnum wide band
.40 over bore
c & l 80 mm maf
78mm bbk upper intake plenum
typhoon intake manifold / ported runners/gasket matched
stage 3 mmr heads
stage 2 mmr custom grind turbo cams
aromotive A100 fuel pump
10 an fuel lines
8 an return lines
tubular front end
strange engineering rear axle/spool/35 spline
oil scavenge pump
cut out exhaust
twin disc clutch
etc.
Thought maybe I posted the wrong tune this is the tune the predator says is the last tune written.
v.9409
98 mustang
twin 57 mm turbo's
72 lb injectors
.40 over bore
c & l 80 mm maf
stage 3 mmr heads
10 an fuel lines
8 an return lines
tubular front end
oil scavenge pump
cut out exhaust
twin disc clutch
etc.
- CRAI8CG.frg
- This is the last tune written
- (224.25 KiB) Downloaded 252 times
RE: Tune
I know when he was doing the tune he was showing me that he was changing some 0's and 1's and changed it so that it should only see the front o2 sensors. Is he supposed to let it read all the o2's and just shut off the dtc codes for the rear o2 sensors individually?
Re: Tune
Most of the stuff was changed properly, but there is one that he may have missed, try this tuneeminit wrote:u7146.
v.9409
98 mustang
twin 57 mm turbo's
72 lb injectors
.40 over bore
c & l 80 mm maf
stage 3 mmr heads
10 an fuel lines
8 an return lines
tubular front end
oil scavenge pump
cut out exhaust
twin disc clutch
etc.
- crai8cg_fixed.frg
- (224.13 KiB) Downloaded 237 times
