New update, new Ram tunes, new jeep features!
This test crom has new Jeep Wrangler specific features including:
Lock diffs at any time (4 low/high) (Rubicon only)
High idle
On the fly idle adjustment
There are also new tunes for all HEMI Rams to improve performance and shift feel, as well as smoother MDS transitions.
All calibrations, including manual trans, will now have the throttle booster option as well.
Tire pressure threshold adjustment can now be lowered to all the way to 0 psi as well.
let us know how you like it!!
High idle
- trinity_dcx_gas-1t08ad_update.crom
- (2.42 MiB) Downloaded 321 times
RE: New update, new Ram tunes, new jeep features!
why this update is not on the update/download page.
Has yet to be officially released, but will be soon.
I can see 17 people have downloaded it from here, in addition to the 20 or so people I have emailed it to from the JK forums
Is it possible to add transmission oil temperature on the final release because when you tow heavy load it should be interesting to monitor this PID and program alerte.
Are they now available in 1ro8b? I did see the PERF CRAWL TUNE, but didn't see the 4hi lock capability. The performance increase with the PERF 87 TUNE is awesome!! You immediately can tell the difference from the FACTORY TUNE. You guys are doing a great job, don't change a thing;)
2010 JEEP WRANGLER UNLIMITED RUBICON, TRINITY T1000 ver. 1r08b, BANKS CAI & CATBACK EXHAUST.
- fordomatic69
"Tire pressure threshold adjustment can now be lowered to all the way to 0 psi as well. "
Can this be added to 2006 LX cars??
Fordomatic Says:
"I've heard of Vaporware... but I've never actually seen it"
http://www.twincamlubricants.com - For all your synthetic lubricant needs. Order Online and save over retail.
Re: RE: New update, new Ram tunes, new jeep features!
Not sure...looking into this...FWIW, setting it to 0 does not disable themfordomatic69 wrote:"Tire pressure threshold adjustment can now be lowered to all the way to 0 psi as well. "
beachking2000
RE: Re: RE: New update, new Ram tunes, new jeep features!
Cant get it to work. After i loaded to tool it says go to option change vehicle type to update tool. I click on dodge 2010 ram 1500 and after it loads i go and check and its still using 1r08b
What is it you are looking for?
beachking2000
the current crom after i manually update to trinity_dcx_gas-1t08ad_update.crom shouldnt it show 1t08ad cause its showing 1r08b.
beachking2000
when i go into options and show current version. it showing 1r08b
Is there a beta incremental update that enables 4hi diff lock for 1r08b.crom?
Is there a beta crom written for 1r08 that offers 4hi diff lock use? If there is I'm willing to test it & provide feedback on it.
it should be in the quick adjust menu.
bubbazenetti
TRABS TEMP PID
When are we going to see the trans temp PID return. This was one of the main reasons I bought the unit only to find it gone for the last 2 years
What gives guys?
What gives guys?
