New Jeep features, new Ram HEMI tunes!
what doesnt work about it?
- sprintertech
mikel wrote:what doesnt work about it?
mike not to sound like a but but just that...it simply does not disable esp/traction control/abs.....they all function normally....ive heard others saying the esp/bas etc. lights remain on with it disabled....mine dont but thats not how im gauging it....they are simply still working perfectly!
so, you turn it off, and it asks you to cycle the key, and you do, then it says successfully updated, but nothing happens?
- sprintertech
come on man...it doesent work....im a lead diesel tech at dodge and have a pretty good idea of whats working or not....mikel wrote:so, you turn it off, and it asks you to cycle the key, and you do, then it says successfully updated, but nothing happens?
but yes....everything is sucessfull but esp/traction cntrl is still very present.....
I have no way to know what you do for a living.
I have to ask, as all you said was 'it doesn't work', I can't just go to engineering and say 'it doesn't work'.
Are you running 9r12?
- sprintertech
sorry....i just knew of no other way to make it any clearer......mikel wrote:I have no way to know what you do for a living.
2010 HEMI RAM 9r12 crom
after disabling esp/traction control when wheels spin occurs it will still pulse brakes and will continue to short shift 1st to reduce engine torque to prevent wheel spin just as its designed to do.........
i would love to have 0 traction control and 0 torque management....
sprintertech,sprintertech wrote: 2010 HEMI RAM 9r12 crom
Us truck guys would all like the same thing. But it ain't happing for us to eliminate TC/TM all the time.
I tried all the tricks in the book but to no avail.
white lightning (Dave Amalong) is the only one I would Highly Recommend to custom tune your tranny. He set mine up and I no longer have ANY TC/TM issues. I introduced him to a few other guys and they are equally amazed as I was to see how much he unleashed with our Hemis. I run nitrous, another is supercharged, and another is turboed. PM me and I can give you more info.
'10 5650 lb LeadSled Crew Cab: 13.401 @ 100.460 MPH
Custom Tunes by white lightning
Pushed & Chilled by Mr. Freeze
- white_lightning
Thank You, Al !VA4MEDS wrote: white lightning (Dave Amalong) is the only one I would Highly Recommend to custom tune your tranny. He set mine up and I no longer have ANY TC/TM issues. I introduced him to a few other guys and they are equally amazed as I was to see how much he unleashed with our Hemis. I run nitrous, another is supercharged, and another is turboed. PM me and I can give you more info.
- white_lightning
I can't totally disable TM, but can probably get you some wheelspin and better shifting pattern.sprintertech wrote: after disabling esp/traction control when wheels spin occurs it will still pulse brakes and will continue to short shift 1st to reduce engine torque to prevent wheel spin just as its designed to do.........
PM me if you want to try a custom tune.
You are more than welcome Dave.white_lightning wrote: Thank You, Al !
I already gave him your email along with a lenghtly review.
- adventurer
- white_lightning
Hate to bother y'all but new to this and trying to find out if the u7137-9t12b.crom works on the 2009 dodge Ram 1500. My predator has the V.9r12 on it. Also when I first programmed on the 93 ran really good out of the whole, but after I turned truck off not running like the 93 was when first programmed. any ideas or suggestions. Thanks
- adventurer
