New Gears, Need to knw how to set the speed right
OK Im not sure what you need so I can change my speedo to where it needs to be, I had trouble setting it be for with the tunner, I had to keep playing with diff tire sizes on the trinity to get it as close as I could. I have a 2000 Silverado Z-71 4x4. It came with factory 373 gear, and 29in tires on 16 in rims, I now have 4.11 gears and 33 in tires on 17 in rims, the tire size is 305-75-17. what do I need to do so that you can change my speedo?
RE: New Gears, Need to knw how to set the speed right
There is gear adjustment right in the Trinity for axle ratio on a 2000 model.
ya but i cant change it to any thing but whole numbers, like 2.00 3.00 4.00, other wise "I cant do any fine adjustments on the actual size.
iv tried the up down, and side to side, just goes from the min to the max, or the whole numbers for the gear
there are 2 adjusters, one coarse and one fine, neither gets you there?
No the course goes strait to the min or max, n the fine goes like 1.00 2.00 3.00 n so on, it won't let me fine tune the ratio
what is the version shown in options/show information?
post your backup and last tune written here and we'll make you a tune to fix it for now.
How do I post my tunes on here? I tried drag and drop and copy and paste but thats not working
click the POST RELY button at the bottom of the page, and in THAT form there's a section where you can attach files...
you can't do it via the quick reply text area... you need to click on the POST REPLY button to get to the other form...
Ok heres the orig., and the tune installed, I have 4.10 gear, 305 65 17 tires on the truck. Also can you deleate the rear O2?
- PCM_381344357700.grg
- The Original Back up
- (26.15 KiB) Downloaded 211 times
- PCM_381344357700_Diablo_Tune_modified.grg
- The Tune installed, Cant Fine tune Rear gear ratio.
- (6.25 KiB) Downloaded 227 times
is this what you need?
This one should be proper, 02's deleted also.
- pcm_381344357700_diablo_tune_410_001.grg
- (21.74 KiB) Downloaded 216 times
Johan< @ >DiabloSport.com
Diablosport INC
Research & Development
Diablosport INC
