99 silverado setting p0748 code
gwukena
Post by gwukena »
99 silverado 4wd ext cab 5.3
Predator U7198 Software rev 2.12
After installing either predator tune, giving 3/4 to full throttle at 1-2 shift, code p0748 is set. Trans shifts hard, if I clear code trans operation normal until throttle mashed again for 1-2 shift. Shutting off truck and driving normal okay, code set once throttle mashed again for 1-2 shift. Does not set this code with factory tune.
Please help
Gary
johan
RE: 99 silverado setting p0748 code
Post by johan »
Does your truck have a shift kit in it? We would kind of need to look at your original tune for the truck to see if there is anything different that would cause this issue.
Johan< @ >DiabloSport.com
Diablosport INC
Research & Development
gwukena
Post by gwukena »
No shift kit installed. How can I pull info on original tune?
johan
Post by johan »
You would need a serial cable and a power adapter, then you would need to download the 99-02 PC interface from our site, upload the original backup to your pc and e-mail that file to us.
If you have any issues doing this, just give us a call and we can walk you through it.
Diablosport INC
gwukena
Post by gwukena »
Thanks for the quick replies, I am on holidays right now, will email you the file next week once I get back.
Gary
gwukena
Post by gwukena »
Johan, sent original tune to you last week, any progress?
Gary
johan
Post by johan »
Hmm, i do not think i got it, can you resend it, i have had an outlook nightmare last week.
Diablosport INC
gwukena
Post by gwukena »
Resent
Gary
gwukena
Post by gwukena »
Any luck?
Gary
johan
Post by johan »
I did not get anything , just check inbox again. you are sending it to [email protected] right?
Diablosport INC
gwukena
Post by gwukena »
Seems for some reason I was dropping the .com part of your email address, sorry for the brain fart,
just resent
Gary
johan
Post by johan »
I got it, ill send you a custom tune in 10min.
Diablosport INC
gwukena
Post by gwukena »
Sweet,
thanks for your excellent customer support.
Just wondering, I currently have a K&N cold air intake and 3" flowmaster cat back exhaust, with a set of short tube headers waiting for install, (summer time) will I need a custom tune for this combination? Is there a 91 octane tune available as only one chain of stations carries 93 where I live, (eastern Ontario Canada) Also how radical can I go before needing custom tunes for additional components ie: cam/rockers, throttle body.
Sorry to be a pain
Gary
johan
Post by johan »
Tune sent, set up for 91 oct. Let me know when you get the header install we will take care of you. If the cam you install is affecting idle quality then you would need to get a tune for that.
Diablosport INC
gwukena
Post by gwukena »
Received tune, top notch customer support even when the customer can't figure out how to send an email.
Will install tune in next couple of days, 25 below farenheit here right now, don't think the battery will be fully up to snuff, will let you know how it works out. If I want to run 87 octane, should I just take out some timing?
Return to “Predator Ford Gas”
