It was used but I was told it had been set back to factory specs and old vehicle info removed.
My question is this. When I plug it into my truck(1999 F250 7.3), The menu screen on the handheld will not light up. Could this be because the last vehicle was not removed properly, or do I have an issue with my port?
Or could the only answer be, The handheld unit is bad?
Any help or ideas would be appreciated.
Just bought a predator
RE: Just bought a predator
Is this unit suppose to have an adapter that plugs into the cigerette lighter? I thought it recieved power when you plugged it in to the port under the dash.
Re: RE: Just bought a predator
The cigerette lighter fuse is also the fuse for the OBD II port on your vehicle. Please check the fuse to see if its blown.elkman wrote:Is this unit suppose to have an adapter that plugs into the cigerette lighter? I thought it recieved power when you plugged it in to the port under the dash.
Cole Stevens
RE: Re: RE: Just bought a predator
Thanks cole and john, problem solved, works great.
