got it sorted out, ran into the exact same issue here on the boss' 2011 CTSV, I am emailing you the update now.11z71 wrote:Well, i downloaded the crom you sent me mike, everything looked good, diablo tranny tunes finally came up in menu, went to install my tunes, backed up originals for both pcm and tcm, the trinity proceded to install pcm tune, then tranny tune, no sooner did the counter start for flash for tranny tune the trinity locked up for whatever reason, then it said in the display that last tune did not finish. the original will be restored, hit ok, restore original back up now? select yes, Tells me unable to restore original backup,select more info and comes up with tcm= error write failed(-18). This is all that it does now when i plug it in, it repeats the same menu's regardless of how long i leave it unplugged, I can't tell whats in the truck for software now, it runs and drives fine, but my trinity is locked now.
You'll need to call from the PC so we can force the update on since the tool is locked.
Once the update is on, it will allow you to restore in recovery mode, then you can tune away
