Regearing options
eterrel
Regearing options
Post by eterrel »
Will you guys be adding the option of adjusting for gear changes ever?
JonDiablosport
RE: Regearing options
Post by JonDiablosport »
what vehicle are you refering too? if you have a Ram the speed sensors recalibrate for them.
Diablosport Tech support
p: 561-908-0040
F: 561-908-0048
eterrel
Post by eterrel »
2011 Jeep, I realize there is no support for them yet however I want to be able to regear later and don't want to spend my money on a programmer that doesn't have this feature.
most wranglers do not need adjustment for gears, as they use the abs sensor at the wheels to measure speed, so you only need to recalibrate for tire height changes.
If it does requrie a gear setting change, it will be there.
eterrel
Post by eterrel »
I'd rather have it and not need it as need it and not have it.
well, we're not into developing features that are not needed.:)
it seems you are under the impression that there are 05-10 Jeeps that are missing this option currently, and that is not the case ;)
eterrel
Post by eterrel »
If that's the case then I'll shop around a bit more
I'm not understanding what the problem is? If it won't do anything, why do you want the option?
yeah, sir, i dont think you are understanding me.
Why do you want a tool that has a gear ratio adjustment that does not do anything???
