Can my Diablosport dealer adjust the fan settings?
Wrxified
Post by Wrxified »
I have a 2011 v6 Mustang. I have a tune that was done on the dyno through my dealer. It's the Diablosport Trinity. My setup is a Procharger kit. With the Procharger tune that came on my SCT tuner they were able to trigger the fan to come on earlier. They (Procharger) had it set to kick the fans on at like 185 degrees and go off somewhere below that. Since I got my tune from the Diablosport dealer I noticed my fan setting are at the stock level. I think they kick on at 200 degrees and go off at 195 degrees.
Can my Diablosport dealer change these settings in my tune or does the Trinity not have this capability?
RE: Can my Diablosport dealer adjust the fan settings?
Yes, they can change anything you want.
If Im not mistaken, you can change that right through the adjustable parameters in the Trinity.
Wrxified
Re: RE: Can my Diablosport dealer adjust the fan settings?
Post by Wrxified »
mikel wrote:Yes, they can change anything you want.
Thanks. I'll check with my dealer. Here are the modifiable parameters I see for my vehicle directly through the Trinity
  • Axle Ratio
    Cam Timing
    Idle
    Mass Air Function
    Rev & Speed Limits
    Spark Advance
    WOT Fuel
RE: Re: RE: Can my Diablosport dealer adjust the fan setting
They should be there, can you post your calibration ID please?
Wrxified
Re: RE: Re: RE: Can my Diablosport dealer adjust the fan set
Post by Wrxified »
mikel wrote:They should be there, can you post your calibration ID please?
Mike - My calibration ID is FMDL9A3
RE: Re: RE: Re: RE: Can my Diablosport dealer adjust the fan
Thanks, we'll check this out.
Wrxified
Re: RE: Re: RE: Re: RE: Can my Diablosport dealer adjust the
Post by Wrxified »
mikel wrote:Thanks, we'll check this out.
Mike,
What did you guys find out on this?
Return to “Trinity Ford Gas”
