calid
Blueox
calid
Post by Blueox »
Hi Guys im having an issue with my trinity. i just got my truck reflashed at the dealer and my trinity is udated to the new crom. it starts fine but as soon as i go to backup the truck file it says it does not support the calid ?
RE: calid
sounds like you now have a newer calibration ID in the ecm than what is supported by the trinity...
it may not let you install a tune, but it should let you save a copy of the original backup stock tune file... is it not letting you even do that??
Blueox
RE: calid
Post by Blueox »
hi thanks for the quick reply. no it still says the trinity is not married. if i try to proceed my truck goes to a no start with engine light on then 5 min later it will start. but the funny thing is i can pull up off the trinty the new files that gm installed
RE: calid
if you clear the codes, it will start.
let it save the stock tune, then export it using DSDL and post it here please, we'll get it added.
Blueox
RE: calid
Post by Blueox »
ok ill try
Blueox
RE: calid
Post by Blueox »
ok i have the original backup on it how do i post it? thankyou
ok figered it out here you go :)
PCM_617631651467.grg
(57.19 KiB) Downloaded 147 times
Blueox
RE: calid
Post by Blueox »
anything on this yet?
RE: calid
will be in the next update...
Blueox
RE: calid
Post by Blueox »
Thank you im just excited to get this thing working :)
Re: RE: calid
Blueox wrote:Thank you im just excited to get this thing working :)
here you go.
trinity_gm_can_gas-1t08gr_update.crom
(1.37 MiB) Downloaded 131 times
Blueox
RE: Re: RE: calid
Post by Blueox »
thankyou soo much !!!!
Return to “Trinity GM Gas”
