Delete logs
Turbozombie
Delete logs
Post by Turbozombie »
Are the logs saved in the DSP delete using the dataviewer program or from the programmer itself? U7134
RE: Delete logs
once you use the dataviewer to get the data log from the predator, the data log is not erased from the predator, but it will be overwritten/replaced once you record a new data log..
Return to “DataViewer/DV2”
