2009+ Cadillac CTS-V
johan
Post by johan »
Mike_Levy wrote:
johan wrote:Let us know on the lag feel also.
The lag off idle is pretty much gone. Theres a slight surge thats happening randomly now. Not able to pinpoint exactly the circumstances (its random :P), so its gonna have to stay.
Ok great, thank you for letting me know on that one :)
Johan< @ >DiabloSport.com
Diablosport INC
Research & Development
TexasCTSV
Post by TexasCTSV »
Thanks for supporting the CTS-V. I am considering buying a Trinity. I currently have a CAI installed, and have a 2.55 upper pulley waiting to be installed. Will the 91 octane tune be safe for this application? Also, the car is an automatic. I understand it will tune the TCM as well. Does it leave enough TM in the transmission to be safe? Thanks.
TexasCTSV wrote:Thanks for supporting the CTS-V. I am considering buying a Trinity. I currently have a CAI installed, and have a 2.55 upper pulley waiting to be installed. Will the 91 octane tune be safe for this application? Also, the car is an automatic. I understand it will tune the TCM as well. Does it leave enough TM in the transmission to be safe? Thanks.
yes, yes, and yes ;)
The 91 tune will work great with your current set up, then swap to the pulley tune once you up the boost.
TM is not removed, just reduced :)
Mike, Are you gonna fix the dashboard or should I mess with it myself?
TexasCTSV
Post by TexasCTSV »
Terrific Mike. Thanks. Just ordered one. How robust is the data logging feature? And is the Trinity set-up to recognize knock retard in case I need to tone things down? I imagine the initial tune is pretty conservative. I live in a hot climate, well above sea level and have 91 octane to boot.
You can see anything you need.
There is a knock pid, and you can see actual timing, commanded timing, commanded AFR, boost, inj pw, and more ;)
The tunes are conservative for sure.
TexasCTSV
Post by TexasCTSV »
Terrific. I look forward to learning the unit.
Spoke too soon. When the car is cold the lag is still there, and it bangs into gear. 43°. Lagged, then it short shifted into 2nd HARD.
See if you can get a log of that...its gonna be a while before we see 43* ;)
It hasn't been getting that cold here either. Next time it does I'll get the log.
08siturbo
Post by 08siturbo »
Hey I was just wondering if the stock injectors could handle 15psi. I am about to put on a 9.1 lower pully to run with my 2.5 upper pulley. So im going to be right at 15psi. I have 80# injectors on hand to put in, but if I do can someone make a base tune for me so I can dial it in myself?
Put it on and then log the IPW to see if they're maxxing out.
You have a bigger heat exchanger, right? Otherwise thats too much boost and you'll heatsoak, get knock and lose power.
08siturbo
Post by 08siturbo »
Ok I have not logged ipw but my idc was at 110% at only 12.75 psi. Which leads me to belive the stockers could not handle another 2 psi.
Your injector has completely maxed out and only ran 100%, you just ran it past its operating range... It is impossible to physically run an injector HIGHER than 100%.
so yeah, if your duty cycle is reading 110%, you need bigger injectors man... generally, you don't want the duty cycle to be more than 80-85%....
08siturbo
Post by 08siturbo »
Ok thats what I was thinking. I will go ahead and put these in next week. Would it be posible to get the pulley tune scaled back for my 80# injectors. Is it something I could do or would have to get done. There is really not a good gm cmr tuner close to me.
Return to “Trinity GM Gas”
