5th gear in Autostick
Nemo
Post by Nemo »
Hi, I just got my Predator yesterday and updated and installed it. I have a 2006 chrysler 300c 5.7L. I intalled the autositck upshift tune and when I switch to autostick from D at a stop , it reads 4 gear. Does predator have 5th gear ? and will it change it so that when I shift to autostick from D at a stop it changes to 1st gear? I ask this cause I just switched from superchip which allowed that. Or did I not installed the right autostick tune? thanks
jumpoo
Re: 5th gear in Autostick
Post by jumpoo »
Nemo wrote:Hi, I just got my Predator yesterday and updated and installed it. I have a 2006 chrysler 300c 5.7L. I intalled the autositck upshift tune and when I switch to autostick from D at a stop , it reads 4 gear. Does predator have 5th gear ? and will it change it so that when I shift to autostick from D at a stop it changes to 1st gear? I ask this cause I just switched from superchip which allowed that. Or did I not installed the right autostick tune? thanks
I dont get the 5 either?
Boggus
RE: Re: 5th gear in Autostick
Post by Boggus »
I just loaded mine in my 06 charger and do have all 5 gears. I have Auto Up Disabled.
Nemo
Post by Nemo »
yeah, found out you have to disable the autostick then you get the 5th gear.
RobAGD
Post by RobAGD »
UNtil the really start digging into the TCM, you are not going to see the same results from the tuning as you did with the SC tuner.
The 5, the Auto Scrol down are all in the TCM from my understanding.
-R
damageinc
Post by damageinc »
just got mine today.....Ive got 5th showing,mines 07 300c
OsuThunder
Post by OsuThunder »
Mine was fine, then today I updated to the new update. its great but my 5th gear no longer showes up either.
I cant shift to it, it just goes back to drive. ALSO I used to be able to, while driving, push the stick right and it would go to the higher gear for that speed..... now it does nothing.
other than that its great so far.
oh yeah, mid 07 RT with R&T
OsuThunder
anyone else? any comments from diablo? just checking.
damageinc
Post by damageinc »
maybe disable mds?then 5 will show...maybe.....????
Jected
Post by Jected »
Issue here and others in Australia. It is like the car now has 2 D's.
The regular D (drive) and the one in Autostick. Definitely not right and needs to be addressed.
Only thing I can fault on the unit.
07 300C SRT8
RDP built 426/RDP-Bullet/Harrop supercharger(Boost 20psi)/HP/F custom fuel &Intercooler system/Nitrous setup/DSS 1000hp Half Shafts/Kooks Headers/Zoomers cat back/Precision Industries 3200
Jected
Post by Jected »
Bump to the top
07 300C SRT8
10SecS4
Post by 10SecS4 »
Mike @ Diablosport started a thread over on the lxforums specifically aimed at Predator shifting/autostick issues. You guys might want to post over on that thread if you haven't already:
http://www.lxforums.com/board/showthrea ... ost1195212
Hope this helps.
